  1. Packs
  2. STM32F769I-EVAL_BSP
STM32F769I-EVAL_BSP
The STMicroelectronics STM32F769I-EVAL Board Support Pack (BSP):
Content in csolution format
Provided API Interface Description
CMSIS_ETH CMSIS-Driver Ethernet connected to Ethernet RJ45 connector (CN9)
CMSIS_MCI CMSIS-Driver MCI connected to microSD card slot (CN17)
CMSIS_USB_Device CMSIS-Driver USB Device connected to USB OTG1 FS connector (CN13)
CMSIS_USB_Host CMSIS-Driver USB Host connected to USB OTG2 HS connector (CN8)
CMSIS_VIO CMSIS-Driver VIO connected to LEDs (LD3, LD1, LD4, LD2) and Tamper button (B2)
STDIN, STDOUT, STDERR Standard I/O connected to Virtual COM port on ST-LINK connector (CN22)
Using GCC Compiler
  • In the <solution_name>.csolution.yml project file select compiler: GCC.
  • Launch the STM32CubeMX generator with this CMSIS-Toolbox command: csolution <solution_name>.csolution.yml run -g CubeMX -c <context>
  • In STM32CubeMX:
  • Open from the menu Project Manager - Project - Toolchain/IDE:
  • Select STM32CubeIDE and disable Generate Under Root.
  • Click GENERATE CODE to recreate the CubeMX generated files for the GCC compiler.
  • In the Board.clayer.yml file, update linker: node configuration to reference appropriate GCC linker script. The GCC linker script is typically generated in the STM32CubeMX/STM32CubeIDE folder. Customize the GCC linker script file to your project's requirements.
  • Rebuild the project using the CMSIS-Toolbox command cbuild <solution_name>.csolution.yml.
