  1. Packs
  2. STM32F769I-DISCO_BSP
The STMicroelectronics STM32F769I-DISCO Board Support Pack (BSP):
Content in csolution format
Provided API Interface Description
CMSIS_ETH CMSIS-Driver Ethernet connected to Ethernet RJ45 connector (CN10)
CMSIS_MCI CMSIS-Driver MCI connected to microSD card slot (CN5)
CMSIS_USB_Device CMSIS-Driver USB Device connected to USB_OTG_HS connector (CN15)
CMSIS_VIO CMSIS-Driver VIO connected to LEDs (LD1, LD2) and USER button (B1)
STDIN, STDOUT, STDERR Standard I/O connected to Virtual COM port on ST-LINK connector (CN16)
ARDUINO_UNO_D2..D10, D14..D19 CMSIS-Driver GPIO connected to Arduino digital I/O pins D2..D10 and D14..D19
ARDUINO_UNO_I2C CMSIS-Driver I2C connected to Arduino I2C pins D20..D21
ARDUINO_UNO_SPI CMSIS-Driver SPI connected to Arduino SPI pins D11..D13
ARDUINO_UNO_UART CMSIS-Driver USART connected to Arduino UART pins D0..D1
Using GCC Compiler
  • In the <solution_name>.csolution.yml project file select compiler: GCC.
  • Launch the STM32CubeMX generator with this CMSIS-Toolbox command: csolution <solution_name>.csolution.yml run -g CubeMX -c <context>
  • In STM32CubeMX:
  • Open from the menu Project Manager - Project - Toolchain/IDE:
  • Select STM32CubeIDE and disable Generate Under Root.
  • Click GENERATE CODE to recreate the CubeMX generated files for the GCC compiler.
  • In the Board.clayer.yml file, update linker: node configuration to reference appropriate GCC linker script. The GCC linker script is typically generated in the STM32CubeMX/STM32CubeIDE folder. Customize the GCC linker script file to your project's requirements.
  • Rebuild the project using the CMSIS-Toolbox command cbuild <solution_name>.csolution.yml.
