- Packs
- STM32C0xx_DFP
STM32C0xx_DFP
2.1.0-
Pack Type
Device Support
STMicroelectronics STM32C0 Series Device Support
Add to CMSIS Solution
packs:
- pack: Keil::STM32C0xx_DFP@2.1.0
Add with cpackget
> cpackget add Keil::STM32C0xx_DFP@2.1.0
Download
STM32C0xx_DFP 2.1.0Introduction
The STMicroelectronics STM32C0 Series Device Family Pack (DFP) is a CMSIS-Pack that:
CMSIS-Driver Support
- component: CMSIS-Driver:GPIO # GPIO Driver for STM32 devices - component: CMSIS-Driver:I2C # I2C Driver for STM32 devices - component: CMSIS-Driver:SPI # SPI Driver for STM32 devices - component: CMSIS-Driver:USART # USART Driver for STM32 devices - component: CMSIS-Driver:USB Device # USB Device Driver for STM32 devices - component: CMSIS-Driver:USB Host # USB Host Driver for STM32 devices
CubeMX Support
- component: CMSIS:CORE - component: Device:CubeMX # Component that connects to CubeMX
Important Note:
The DFP does not contain Startup and System Configuration files and does not provide the
CMSIS_device_header
provided by the CMSIS-Core that defines the registers and interrupt mapping. This files are provided by the CubeMX firmware pack. It is therefore mandatory to use CubeMX when using this DFP as it will pull-in these files and make it accessible.Usage in VS Code
In the dialog Create New Solution choose a device or board and select a CubeMX template (which contains the
Device:CubeMX
component). -
Use
Run Generator
that is available for the componentDevice:CubeMX
in the CMSIS Solution View. This starts CubeMX and once the configuration is complete, click in CubeMX the buttonGENERATE CODE
. The generated code is imported with fileCubeMX.cgen.yml
as shown below.
Note:
Usage in uVision
Select a device and enable in the Manage Run-Time Environment Window the components:
CMSIS:CORE
Device:CubeMX
Use
Launch CubeMX
in the Manage Run-Time Environment Window. This starts CubeMX and once the configuration is complete, click in CubeMX the buttonGENERATE CODE
