- Packs
- NUCLEO-H563ZI_BSP
NUCLEO-H563ZI_BSP
1.0.0-
Pack Type
Board Support
STMicroelectronics STM32H5 Series NUCLEO-H563ZI Board Support Pack
Add to CMSIS Solution
packs:
- pack: Keil::NUCLEO-H563ZI_BSP@1.0.0
Add with cpackget
> cpackget add Keil::NUCLEO-H563ZI_BSP@1.0.0
Download
NUCLEO-H563ZI_BSP 1.0.0NUCLEO-H563ZI_BSP
The STMicroelectronics NUCLEO-H563ZI Board Support Pack (BSP):
- Contains examples in csolution format for usage with the CMSIS-Toolbox and the VS Code CMSIS Solution extension.
- Requires the Device Family Pack (DFP) for the STM32H5 series.
- Is configured with STM32CubeMX for the Arm Compiler 6 (MDK). Using GCC Compiler explains how to configured it for a different compiler.
Content in csolution format
Examples/Blinky shows the basic usage of this board.
Board Layer for device-agnostic Reference Applications that implements these API interfaces:
Provided API Interface Description CMSIS_ETH CMSIS-Driver Ethernet connected to Ethernet RJ45 connector (CN14) CMSIS_USART CMSIS-Driver USART connected to ZIO pins D52, D53 (CN9) CMSIS_USB_Device CMSIS-Driver USB Device connected to User USB connector (CN13) CMSIS_VIO CMSIS-Driver VIO connected to LEDs (LD3, LD1, LD2) and USER button (B1) STDIN, STDOUT, STDERR Standard I/O connected to Virtual COM port on ST-LINK connector (CN1) ARDUINO_UNO_D2..D10, D14..D19 CMSIS-Driver GPIO connected to Arduino digital I/O pins D2..D10 and D14..D19 ARDUINO_UNO_I2C CMSIS-Driver I2C connected to Arduino I2C pins D20..D21 ARDUINO_UNO_SPI CMSIS-Driver SPI connected to Arduino SPI pins D11..D13 ARDUINO_UNO_UART CMSIS-Driver USART connected to Arduino UART pins D0..D1 Using GCC Compiler
- In the
<solution_name>.csolution.yml
project file selectcompiler: GCC
. - Launch the STM32CubeMX generator with this CMSIS-Toolbox command:
csolution <solution_name>.csolution.yml run -g CubeMX -c <context>
- In STM32CubeMX:
- Open from the menu
Project Manager - Project - Toolchain/IDE
: - Select
STM32CubeIDE
and disableGenerate Under Root
Click
GENERATE CODE
to recreate the CubeMX generated files for the GCC compiler. -
In the
Board.clayer.yml
file, updatelinker:
node configuration to reference appropriate GCC linker script. The GCC linker script is typically generated in theSTM32CubeMX/STM32CubeIDE
folder. Customize the GCC linker script file to your project's requirements. - Rebuild the project using the CMSIS-Toolbox command
cbuild <solution_name>.csolution.yml
