- Packs
- CMSIS-RTX
CMSIS-RTX
5.9.0-
Pack Type
Software Pack
RTX RTOS implementation of CMSIS-RTOS2 API
Add to CMSIS Solution
packs:
- pack: ARM::CMSIS-RTX@5.9.0
Add with cpackget
> cpackget add ARM::CMSIS-RTX@5.9.0
Download
CMSIS-RTX 5.9.0Change Log
Version 5.9.0: May 16, 2024
Recommended
Get Pack-
packs:
Add with cpackget
Download
CMSIS-RTX 5.9.0- Enhance conditions to support Cortex-M52 - Remove dependency on Device:Startup component
Version 5.8.0: Dec. 19, 2023
Get Pack-
packs:
- pack: ARM::CMSIS-RTX@5.8.0
Add with cpackget
> cpackget add ARM::CMSIS-RTX@5.8.0
Download
CMSIS-RTX 5.8.0First release of separate pack shipping RTX5 RTOS implementation for CMSIS-RTOS2 API. Changes since RTX 5.5.4: - Based on CMSIS-RTOS API V2.3.0 (processor affinity not supported). - Added support for Process Isolation: MPU Protected Zones, Safety Classes, Thread Watchdogs. - Requires CMSIS:OS Tick:SysTick component. - Reduced component variants: Library (Library_NS replacement), Source (Source_NS replacement). - Libraries for Arm Compiler 6 built with default wchar and enums size. - Added pre-built libraries for GCC, CLANG and IAR. - Removed support for legacy Arm Compiler 5. - Fixed osMessageQueueGetSpace when called from ISR after osMessageQueuePut and before returning from ISR. - Added de-allocation of Arm C library thread data (libspace) when thread is terminated. - Added Thread Entry wrapper (compatible with GDB stack unwind). - Updated SysTick implementation for OS Tick (initial count value).
