STM32H747I-EVAL
Rev.B
Cores
Cortex-M4
Cortex-M7
Debug interfaces
ST-Link
JTAG/SW
Device
STM32H747XIHx -
CMSIS Pack
STM32H747I-EVAL_BSP
STM32H747I-EVAL Evaluation board
Overview
The STM32H747I-EVAL Evaluation kit is a complete demonstration and development platform for Arm® Cortex®-M7 and Arm® Cortex®-M4 core-based STM32H747XI microcontroller, with 2 Mbyte of flash memory and 1 Mbyte of SRAM.
The STM32H747I-EVAL Evaluation kit is used as a reference design for user application development before porting to the final product, thus simplifying the application development.
The full range of hardware features available on the board helps users to enhance their application development by an evaluation of all the peripherals (such as USB OTG HS and USB OTG FS, Ethernet, USART, CAN FD, audio DAC and ADC, digital microphone, SRAM, SDRAM, NOR flash memory, twin Quad-SPI flash memory, microSD™ 3.0 card, RGB interface LCD with capacitive touch panel, and others). The expansion connectors provide an easy way to add specialized features, while ETM trace is supported through external probes.
STLINK-V3E is integrated into the board, as the embedded in-circuit debugger and programmer for the STM32 MCU and USB Virtual COM port bridge.
Getting started
ST-LINK driver installation and firmware upgrade (on Microsoft Windows)
- Download the latest ST-LINK driver.
- Extract the archive and run
dpinst_amd64.exe
. Follow the displayed instructions. - Download the latest ST-LINK firmware upgrade.
- Extract the archive and run the
ST-LinkUpgrade.exe
program. - Connect the board to your PC using a USB cable and wait until the USB enumeration is completed.
- In the ST-Link Upgrade program, press the Device Connect button.
- When the ST-LINK driver is correctly installed, the current ST-LINK version is displayed.
- Press the Yes >>>> button to start the firmware upgrade process.
